I have a 1972 Datsun 240Z and my 09 Cube has the same bolt pattern. That opens up a lot of wheel options.
That's kinda cool! A little nostalgic wheels made from the same brand. Pics please =)
I have the same bolt pattern and rim/tire size on my two cars, but I was really dissapointed when I found the OE steel rims for the newer car wouldn't fit on the hubs of the older. It would have been nice if my snows could have gone on either. Still, the aftermarket rims are interchangable, I'd just have to keep the plastic hub center rings with the older car.
Have you test fit these?
I had two different Toyota Corolla's back in the day that has the same bolt pattern and size, however the shape of the wheel hit the caliper on one car and not the other. One was a fast back and the other a notch back. I fixed the problem by shaving the break pads. NOT RECOMMENDED!
