If you look really close, you'll see in the center it (for lack of better words) rolls out a little bit in the center.
Someone with this add hopefully will post a bigger better detail pic.
Nissan is failing with those thumbnail sized pics.
It's different but only slightly that I can tell from their website.
I've seen the hood moulding accent. All it does is adds a bit of a lip that kinda hangs over the gap between the center section of the hood and grille. IMHO I think it looks a bit tacky. Not that the overhanging lip looks bad, it actually looks good. But the moulding itself is just a stick on applied to the front of the hood, and you guessed it, it looks like a stick on. Doesn't blend itself well. - Dan
