You have seen these around or advertised and wanted to learn a little more. Well here is your opportunity.
I purchased these from the manufacturer directly on the 4th of September for $29.99 for the 7507 bulbs and $7.95 in shipping. Total: 37.19
They were shipped from the manufacturer to me on 10 September UPS Ground. 7 Days Later!
The box arrived at my door on 16 September. It was advertised UPS Ground (signature required) but the box was left, this may be UPS’s fault.
I think either they are a conscious recycler of old boxes or they get allot of RMA, I don’t know which.
Open the box and they appear adequately packed in the foam peanuts.
However after digging thru the peanuts this was in the box. The package was open and the bulbs loose but not out of the packaging.
Well lets check and make sure they work. A quick examination reveals the chrome coating is applied evenly and looks rich in amber color.
OK they work, so let see how they compare to stock bulbs.
You can see the stock bulb is considerably brighter. The stock bulb is 21 watts, the stealth bulb has no wattage markings and none on the package or website either.
Here is what the bulbs look like side by side, stock VS chrome.
In this picture you can see the stealth bulb on the right and stock on the left (your left). The stock bulb gives you the appearance of an egg yolk in there.
Here with both bulbs on you can see how dim the stealth is compared to stock on the left.
Below is a shot with both stealth bulbs installed.
A close up of the installation shows the bulb just disappears in there, or does it?
When the sun is shining brightly on the bulb it has a brown cast in the bucket, not so stealth now!
I found a pair of stealth/chrome bulbs (no name brand) over on Ebay for $4.00 plus shipping that was 27 Watts, this may be as bright as the stock 21 Watt. The Stealth bulb claims it is an heavy duty bulb and offers an lifetime warranty. They claim the cheap knockoffs can break and wear out prematurely. Now you have a review to decide if you should spend almost $40.00 for this mod.
I like the look and I am happy with it overall. Good Luck with yours and I hope this was useful.
Christine
Christine
