Buying a Cube could not be easier. Service on a Cube is a royal PITA. Twice now I have setup my appointment for my free oil change, tire rotation, and car wash. They are now 2 for 2 with a complete lack of service. I on both occasions sat in the waiting area by the window and watched as they changed the oil and pulled it back around claiming they were finished with the service. I sent them back both times for the tire rotation and car wash which on the first fail they did neither and claimed a lack of manpower and time and the second time I raised a stink with the manager and watched as they rotated the tires and than tried to not wash it. I made noise again and they took it back and washed it inside and out as the manager and I both watched.
I also helped 2 guys in the waiting room out with the failed service they were experiencing when one was told $647 for a air fuel sensor due to a out of range fuel reading on the left bank with a code p1273 (Mass Air Flow Sensor) I told him the dealer was full of crap and sent him to AutoZone for a new sensor helped him install it and problem solved for less than $100. Second guy brought his new truck in for a battery recall and his radio stopped working and vdc light came on when the finished. I showed him the button for vdc and told him to have the dealer replace the fuse for the amp for his Bose system. Needless to say they wanted to charge him $450 for a new radio until he asked about the fuse for the amp that they most likely blew while replacing the bad battery.
Stealership service at its best got to love when they try to steel someones money right in front of you.
Dink
Dink
