2010 Nissan Cube Krom
Serpentine belt broke off and all the accessory lights came on, power steering, battery, brake etc etc... Car went into limp mode. Had to drive just a few mins to get home.
Went and purchased a belt came back home and installed it. I left the terminals off hoping the computer would reset..
I hooked the battery back up and started the car. But the battery light is still on as well as the brake light. I fully charged the battery "purchased this year" and the battery light and brake light are still on.
Has this happened to anyone? The car was running perfectly fine before this happened.
possibly reset the computer. disconnect the negative battery terminal for 30 min. This should reset the computer
I am a professional mechanic. I wish people would stop spreading the BS that disconnecting your battery will "reset" your computer! It won't.
95 % of the cars that I work on with a broken belt are caused by one of your accessories (alt, A/C, idler pulley etc). You probably have a bad alternator. I ALWAYS recommend to my customers to replace the alt AND battery at the same time.
Disconnecting the battery does reset the computer, may not fix your problem but it does reset it
