I have noticed a rattle in the emgine when stopped. So I did a little checking to see under what circumstances it makes the noise. If I sit in neutral with the clutch out no noise. If then put the clutch in but still in neutral no noise. But if I keep the clutch in and then put it in any gear the noise starts. Also noiced that at idle with clutch in and then put in gear the engines raise slightly in RPM's. It suppose to do that not really sure. Has anyone else noticed the noise ?
