My power window auto-up quit working after I disconnected the battery to install my alarm sensor. After reading the PWC service manual section, thanks Boxcar, I found that you must reset this every time you disconnect the battery. :yes:
ADDITIONAL SERVICE WHEN REMOVING BATTERY NEGATIVE TERMINAL : Special
Repair Requirement INFOID:0000000005059986
INITIALIZATION PROCEDURE
1. Disconnect battery minus terminal or power window main switch connector. Reconnect it after a minute or
more.
2. Turn ignition switch ON.
3. Operate power window switch to fully open the window. (This operation is unnecessary if the window is
already fully open)
4. Continue pulling the power window switch UP (AUTO-UP operation). Even after glass stops at fully closed
position, keep pulling the switch for 2 seconds or more.
5. Initializing procedure is completed.
6. Inspect anti-pinch function.
CHECK ANTI-PINCH FUNCTION
1. Fully open the door window.
2. Place a piece of wood near fully closed position.
3. Close door glass completely with AUTO-UP.
• Check that glass lowers for approximately 150 mm (5.9 in) without pinching piece of wood and stops.
• Check that glass does not rise when operating the power window main switch while lowering.
Hope this helps someone from going to the repair shop after you disconnect the battery. 8)
more.
already fully open)
