Hi
I am getting a check engine light code P0463 fuel level sensor circuit high
Car runs fine
However when gas tank is low the check engine light comes on. Goes away after fill up of gas and driving for a few days
Mechanic wants to replace the whole fuel assembly unit for $900 Canadian dollars!
Anyone with experience with this issue?
Thanks
Hi
Car runs fine
Thanks
So I've had the same problem with my cube, What I did was use my code reader obd and just cleared the code. It really never comes unless I run my gas tank dry. You just need to keep you tank at least 1/4 at all times and never let it run almost empty. I have read people having this problem but if you follow what I did you should be fine. Once the code is cleared using the one scan tool I havnt had a problem. Hope this helps
