I bought a 1.8S with the Ginormous Package...I know the SL has the outside temp on the guages...Does anyone know if this can be added by just adding the sensor or do you have to have the auto AC unit??
Im planning to do this with alot of "extra" stuff that didnt come on my base Cube.. If they are the exact same clusters(same part#) then yes, it would need to be turned on somehow.. It would be adding the temp sensor in addition to this.. I doubt just installing the sensor would make it work because let say you had a bad temp sensor.. The display wouldnt just show nothing, it would show like -396 degrees or something like that.. So there is surely some way to "turn on" the display to make it work..jasonbillups said:It's the same cluster but I just don't how to make the outside temp to come on....either I need to add a sensor or it might just need to be turned on.....
just like the fog lights I just installed...I took out the plastic fillers for the fog lights pushed them in place and the wiring was already there..I just plugged them in...the only thing additional is that I changed the switch inside which comes with the fog lights
