My 2010 Cube is no power on the OBD2 port , anyone can help? Is there a fuse ?
Sent from my iPhone using Tapatalk
Had the same issue with the 2009 cube. Pin # 13 may be loose or not connecting resulting in a falure to power the OBDII port. This was noted when I took it in for emissions testing. At the time I had my GPS plugged into the power outlet. Removed any plugged in accessories and the OBDII port was able to power up no issue. Not sure if that will work for you but worth a shot!
