Can someone please answer the following questions
1) How do I know what type of A/C Blower Motor my Nissan Cube 2004 has?
2) it needs replacing, is it an easy job, or best left for a mechanic?
I have checked the fuses, they are fine, there is NO air coming from the vents, so I have concluded that it most likely is the Blower motor, thankyou.
1) it's in your tech book
2) it is better of course to contact a specialist in the service
No need to be coy. Not everyone can afford service at a dealership etc. And manuals get lost. This is an information sharing site not a place to be rude.
Hi Harry, did you sort the AC blower motor? I have exactly the same issue on my 2003 Cube 3. I was going to check the fuses today. Seems to be a common fault. I also need to get the cigarette lighter working again. I imported it from Japan to the UK. A copy of the manual cost me £35 on ebay but doesn't cover everything. Hope its gone well for you.
