Here is a copy of the 09 Nissan Cube Factory service manual and owner's manual in PDF format. Call it a thank you for the great forum! Also wanted to thank Amnesiac for the server space. You were a huge help, thank you!
As time goes on I can only see this forum growing and getting better. Hope this little contribution helps all of you along the way. As this begins to spread around the net please remember which forum it came from and why it was posted. Enjoy!
**The index is located in file fwd.pdf**
FWD - Index
ACC - Accelerator Control System
ADP - Automatic Drive Positioner
AV - Audio, Visual & Navigation System
BCS - Body Control System
BR - Brake System
BRC - Brake Control System
BRM - Body Repair
CHG - Charging System
CL - Clutch
CO - Engine Cooling System
DEF - Defogger
DLK - Door & Lock
DLN - Driveline
EC - Engine Control System
EM - Engine Mechanical
EX - Exhaust System
EXL - Exterior Lighting System
EXT - Exterior
FAX - Front Axle
FL - Fuel System
FSU - Front Suspension
GI - General Information
GW - Glass & Window System
HA - Heater & Air Conditioning System
HAC - Heater & Air Conditioning Control System
HBB - Hybrid Battery System
HBR - Hybrid Brake System
HRN - Horn
INL - Interior Lighting System
INT - Interior
IP - Instrument Panel
LAN - LAN System
LU - Engine Lubrication System
MA - Maintenance
MIR - Mirrors
MWI - Meter, Warning Lamp & Indicator
PB - Parking Brake System
PCS - Power Control System
PG - Power Supply, Ground & Circuit Elements
PWC - Power Window Control System
PWO - Power Outlet
RAX - Rear Axle
RF - Roof
RSU - Rear Suspension
SB - Seat Belt
SBC - Seat Belt Control System
SCS - Suspension Control System
SE - Seat
SEC - Security Control System
SN - Sonar System
SR - SRS Airbag
SRC - SRS Airbag Control System
ST - Steering System
STC - Steering Control System
STR - Starting System
TM - Transaxle & Transmission
VTL - Ventilation System
WCS - Warning Chime System
WT - Road Wheels & Tires
WW - Wiper & Washer
Here's the complete FSM and owner's manual in a ZIP. I'm not sure how long these outside links will last but it should help take some of the initial burden off of the forum servers.
http://www.zshare.net/download/63193378d9e6011f/
http://www.sendspace.com/file/2p623c
FWD - Index
BR - Brake System
BRM - Body Repair
CL - Clutch
DEF - Defogger
DLK - Door & Lock
DLN - Driveline
EX - Exhaust System
EXT - Exterior
FAX - Front Axle
FL - Fuel System
HRN - Horn
INT - Interior
LAN - LAN System
MA - Maintenance
MIR - Mirrors
PWO - Power Outlet
RAX - Rear Axle
RF - Roof
SB - Seat Belt
SE - Seat
SN - Sonar System
SR - SRS Airbag
WW - Wiper & Washer
