Hello all. So excited to be in a cube - even if I'm experiencing my first issue here. I'm hoping someone else has had the same problem or has helped someone who has - it's weird and all the Googling I can do isn't coming up with the same issue. Or it's just not being described the way I'm seeing it play out.
My cube is a 2009, pretty sure it's one step up from the base model. It's not a Krom. I was fitting new roof racks (ski season is coming) today and had the doors open quite a bit. When I was done I went to start the cube and it wouldn't. I thought maybe it was the battery so I put my charger on it and charged it up until the charger readout said 100%. Still no go. So I started trying to figure out what was happening so I could search for solutions.
Power is good, key FOB works fine, spare FOB as well. When I hop in the cube, press the brake pedal and hit the start button the steering lock retracts, the dash lights up and that's about it. After a second or two the radio comes on and the "press brake" light comes back on. It appears to have gone to ACC mode after "trying to start" but failing to activate the starter. If I release the brake and just hit the button it "turns off" and I hear the steering gear relock the steering (and confirmed the steering does indeed lock).
Is this the symptom of the ESCL? Does the car still light the dash etc and then go to ACC mode or will the button not even wake the system up and 'try' to start the cube?
Brake lights work fine, shouldn't be the brake switch. I hope it's a known ESCL issue here....I can drive my truck but LOVE my cube and want to drive it! Thanks in advance for any wisdom and thank you for welcoming me into the forum!
