1 - 1 of 1 Posts
Hello everyone!
So, str8 to it. My cube needed a new cat. Friend mechanic found rusted fuses bolt and was advised to just cut thru it. "I" have some working skills and since no torch initially felt that a scientific approach may "at least" help. I researched and found several "dissolve rust" at least remove as much as possible. He shot the idea full of holes, took a cutter to it a d though.the.cat if off....there's still a bolt stuck "waaay up in there" he says and it's on a bad angle maybe a "L" shaped drill I can drill thru middle and blah.....blah. I NEED TO WORK AND GET TO hospital, medical issues. Since he removed it what else can he do to get my cat on my car?
1 - 1 of 1 Posts
