Im not very savy with engines. Can someone tell me if the 2009-2014 Nissan cubes the brake reservoir and manual transmission reservoir is the same?
That's what it looks like in the owner's manual? So does that mean changing the brake fluid is also changing the manual transmission fluid?
This may seem like a dumb question but Im not that engine savy
You need a lift (cube must remain level)
A 1/2 drive socket wrench to pull the plug (you actually put the socket set nub right into the plug).
Manual transmission oil: Genuine NISSAN gear oil (Chevron Texaco ETL8997B) 75W-80 or equivalent*4
