1 - 1 of 1 Posts
Hi Cube owners. I have just purchased a 2005 cube with wheel chair ramp. I can't sort out the best way to lock down the wheel chair... the front tie downs are connected a retractor system on the floor, but the belts don't seem to hold tight unless the rear door is closed. There is also a switch on the left side of the rear opening, above the raise lower switch, that doesn't seem to do anything..
Would appreciate any guidance as don't want to travel with daughter in the back until I know ive set it up correctly..
Thanks, Tim
1 - 1 of 1 Posts
