Yeah you will probably also need an antenna adapter and wire harness. Both can be picked up at Best buy or any car audio store... If they don't have it specifically for the Cube, you can use the versa ones.
ya that is the 09 model of mine its super easy bolts in really some.. no mods to make it fit... you just need antenna adapter and wire harness for a 07-09 versa thats what i did...... then you will need a switch to watch dvds when driving but that took 3min to do too.....
