1 - 1 of 1 Posts
I might have posted this before - but maybe not. If you have to replace the bulb in the high brake light, you must first pry off the plastic trim inside. That can be tricky. There are four pins holding it on, and if you pry in the wrong place, you could break something. I have included a picture with measurements to the four clips. By the way, when you pry, insert the tool between the door and the trim and pull toward you. Do not push the tool up against the door body.
1 - 1 of 1 Posts
