Hello, I am in great need of your expertise. I have a Cube Krom 2010 with the start button. The vehicle doesn't start, but it goes into accessory mode. I have recent battery and I also changed the batteries in the 2 key fobs. Do you have an idea of the problem that would prevent me from having my Cube towed to the garage?
It's possible that your Stop Light Switch went bad. This happened to me where I wasn't able to get the car started unless I fumbled around with the switch, which sometimes helped. But you are going to want to replace it with a new one. There about 20 bucks to replace and pretty easy to do.
If you have a 6 speed manual. It could be the clutch starter safety switch. The car won't start unless the switch recognizes that the clutch pedal is pushed down.
Do you have any warning lights on the dash? If there is an orange light with a key, your electronic steering column lock could be faulty.
