1 - 5 of 5 Posts
it can be pretty much cosmetic, the guys at NRG didnt want to put theirs on my cube because they showed me the cube already haves a pretty good grounding system going on in the engine....
Not to dis anyone or anything like that. But Grounding kits are nothing more than a scam. All cars come with factory grounds as they should. And good grounding is extremely important to a healthy charging system. But what comes from the factory should be more then adequate. Not to take away from the fact that some aftermarket ground kits do look good, and adding more ground straps is always a plus (no such thing as too much ground). But the truth of the matter is, if adding a ground kit improves anything, then you should look around. You will most likely find a bad or missing factory ground strap. - Dano
BTW, I am a certified automotive electrician by General Motors and the US Navy and will be more than happy to post my credentials.
1 - 5 of 5 Posts
