1 - 10 of 10 Posts
I just got my Cube and winter started here in Ohio. Well I was running out of windshield washer fluid all the time. Wow and I could only get 1/4 of a container of washer fluid in at a time. Well my washer tank was frozen, Nissan did not use washer fluid with antifreeze in it. I let it sit inside with the heat on and pumped all the washer fluid out and put new anti freeze fluid back in. I hope it did not damage the pumps.
Wow! You're saying the factory/dealership prefilled the windshield washer reservoir with plain water? Not the standard antifreeze/water mix? That's astounding! I'd definitely rag on the dealer over that one :mad:! From what I've read in the past, plain water should never be put in washer reservoirs (same for radiators) -- even if the temp is always above freezing, the fluid needs to provide lubricants for the pump.
Probably not plain water, just plain washer fluid, not the winter mix.
What's the difference? If I go to PepBoys to buy windshield washer fluid, I'm looking at 50/50 mix, not something else. what do you have in mind?
The difference is the percentage of methanol in the mix. Regular fluid is good to freezing or just below. Winter mix is good to around -40, depending on the brand.
Methanol - reminds me of Fast & Furious :D
I will have to look for this mix, as my current mix takes a while to warm up enough to come out of the nozzles.
Interesting! Just took a look for my windshield washer fluid to read the label, but failed to spot it. I'll check PepBoys tomorrow. I've been keying off the 50/50 mix I'm used to in radiators (good for well below feezing), but maybe it's indeed different. Never had washer fluid freeze on me though :p!
It is a Fast and the Furious thing LOL... lots of forced induction guys that run meth injection use windshield washer fluid for the methanol supply.
I believe there's a version of ethelene glycol that can be used for washer fluid too, but it's a non-toxic version...
Checked at PepBoys today :)! They have two windshield washer fluids available, one good to -20F and another brand good for -25F (looked as though this was 40% non-water ingredients). Both well below freezing (32F), yet neither marked as being something special for winter, etc. Coldest it ever gets around here is around 18F I think, but maybe it's a region thing -- perhaps in Florida or Southern California the minimum temp is higher :-\?
PS. Here's an interesting thread on the subject of home-made washer fluid :)
http://www.thriftyfun.com/tf883828.tip.html
1 - 10 of 10 Posts
