Just picked up a 2009 Cube and there is some play in the door hinge pin, looks like the busshing on the upper driver side door is worn. Local NAPA shop has no listing for a hinge or pin for the Cube. Searching this forum and the net for a kit or even info on whither the pins are replaceable has got me nowhere. Anyone know what pin kit will work or a good parts site to get replacement hinges?
Psy
Looks like it will be a hinge assembly from Nissan. From what I saw, they run about $60. You might be able to replace the bushing if you can order by size from a hardware outlet like McMaster.com
Check out TascaParts.com they have parts well below dealer prices. I've found many parts for my 2012 Cube and my 1994 Nissan Pickup at great discount. Here's a direct link to door parts. There are upper and lower hinge parts listed for all 4 doors. I searched for Door Hinge Assembly. Cube Door Hinge Parts
