1 - 20 of 28 Posts
Standard Ripple Hook
Chrome Ripple Hook
Compare Plastic Factory Hook to Cabinet Knob from Lowes.
Just under $4 each can be cheaper or way more expensive depending on the look you want. All you need is a Cabinet handle with a flared base and you will need to replace the 1" long 8/32 screw that comes in the package with a 1/2" 8/32 screw which you can also buy at Lowes.
Dink
Perfect addition for the Krom. :yes: Bump for the idea. Thanks. 8)
Update. Went to Lowe's this a.m. Spent $15.95 CAD and I have a set of 4 DIY Ripple hooks. I went with black pulls because I thought the chrome would stand out too much on my charcoal and black interior. Included in that cost were washers and ring-lock washers to make sure I could tighten the hooks up and they would not loosen over time. Sorry, no pix, as I have no digital camera. Thanks to OP for the idea. The rest of you should definitely go this route, as it is about half the cost of OEM part, and you can decide what you want them to look like. Mine have 3 concentric rings that have a braided rope effect. Much jazzier than the OEM part, imo.
I have just installed the DIY hooks in the front spots and put the originals in the back doors.
I found some black [ugh! and cheap!] shiny plastic knobs at Canadian Tire.There is no Lowe's here.
Could not find the type like yours.
However I sprayed them with some good flat black paint.
The diameter is slightly larger but actually it is an advantage for larger bag handles etc.
They don't look out of place.
Cheers,
Bryan.
Discussion Starter · #10 ·
none said:
A tire store sells hardware? Where do you live again?
Up here in the ever so hot,hot in the 80's F Victoria,British Columbia,Canada.
Not exactly the great white North lately!
We are on Vancouver Island and I can see Washington State [San Juan Islands]and Mt.Baker in all its snow capped glory in the distance in the USA.
Canadian Tire is originally a long time Canadian icon selling auto Parts but as with most stores today sells everything even the kitchen sink!
Cheers,
Bryan.
Notice the e-slay ad for chrome ripple hooks? Only $27 each for buy it now price. :no: It would be interesting to see if they are cabinet pulls. :D 8)
Discussion Starter · #15 ·
It is actually $27 for a set of 4 with the 1/2 inch screw locked in with red loctite at the proper depth so they just pop on when you get them. I have sold 3 sets so far. Not bad for a $20 per set investment.
Dink :p
Dink- I don't know how but I figured it was you. :D I almost sent you a note first. Thanks for correcting the qty as 4. You go make some coin and you'll have your Qb paid for in no time. :yes: 8)
ChristineK said:
Here is my DIY ripple hooks. :yes:
These have the ripple circles so it matches well and the tone of the metal is perfect. 8)
These are really good Christine! :yes: :yes:
Where did you get them as they sort of look like brushed stainless.
As you say the tone is perfect and far superior to the originals. 8)
I will now go back to the DIY stores and look more closely.
Cheers
Bryan.
Cheers
Bryan.
I got them at LOWE's for $1.97 each and bought shorter screws but I still had to cut them so I could have used the one in the bag and cut those down to size and saved $1.00. The red is nice but in the pics (it may the the pic) over powering on the interior.
1 - 20 of 28 Posts
