All doors will be locked automatically when the vehicle speed reaches 15 MPH.
All doors will unlock automatically once the key is removed from the ignition.
To activate or deactivate the vehicle speed sensing door lock mechanism, perform the following procedure.
1. Close all doors.
2. Turn the ignition switch to the ON position.
3. Within 20 seconds, push and hold the power door lock switch to the LOCK position until the hazard lights flash. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
To activate or deactivate the automatic door unlock mechanism, perform the following procedure:
1. Close all doors.
3. Within 20 seconds, push and hold the power door lock switch to the UNLOCK position until the hazard lights flash. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
I will not use this but this a one of those simple things that when they just happen are hard to find a "How to" around. Thanks a lot bro!
Premium Member
I agree..
Side Note: For those with Push Button Start, you have to turn it to ACC (push start twice w/ foot off brake).
