Coolant system
129 Views 2 Replies 3 Participants Last post by  hondo1
Our poor 2004 cubic is in need of some work on the coolant system. I know the parts manual is insanely difficult to get hold of, so wondered if anybody knew the part number or knew where I could get a thermostat and water pump? Our parts dealer is unsure the one they can supply is right.
Hey try getting a Nissan Versa manual like a Chiltons repair manual prob spelled it wrong.
  • Like
Reactions: 1
I believe you’re in Canada. You can enter the vin # on the Nissan web site parts page yourself. Nissan parts department should be able to ID the correct water pump & thermostat. If they are the wrong parts. You should be able to return for fully refund.
I’m not sure you have access to Rockauto but check their web site.
Worst case scenario, you might have to remove the thermostat and water pump and bring it to them to compare. it’s a 2004 Cube parts might be limited to the age but the Versa or similar models might have the same parts.
I believe you don’t need to parts manual. you can watch lots of videos they show you how to do it without the parts manual. it’s not hard you just Gotta have a garage and a floor jack & some jackstands.
Since YouTube, you don’t need any parts manual for anything.
  • Like
Reactions: 1
