That is not true, I have a 2010 base model and when you go under the car and pull the front bottom panel off you will see the plugs for the fog lights.
But you need to buy the oem fog lights that come with the switch on the turn signal. If you buy the oem kit it comes with the replacement switch.
So did you install them? I was wondering if you installed your own switch for the lights or installed the OEM Switch. I honestly do not want to remove the steering wheel if I don’t have to.
You don't remove the steering wheel, just the wiper stalk on the left side of the steering wheel, very easy. Plug and play. Getting your hands up and behind the fog light is the tricky part
