1 - 8 of 8 Posts
Hello,
I am picking up my cube in about a week and I was wondering if the factory radio in the 1.8SL with the rockford fosgate upgrade has RCA outputs on the back so I could hook up my own amp/sub combo. I would just pull the radio out if I had it but I can't yet and I want to know what I need to install my amp when I pick up the car.
Thanks
I doubt it but it may....You can hook up an amp to any factory system...I would just come off the speaker wires and use a amp that has high level input...Arc Audio will take up to 400 watts on the high level input and you don't need to run RCAs...Heck the ARC amps will turn on hooking it up this way, so you don't even need to run a remote turn one ;D
I'll probably just order a line out converter. I have a Rockford Fosgate Punch P8002 800-watt amp and 2 Diamond 12" Hex Pro subs and the amp doesn't have a high-level input so I'm gonna have to convert it to RCA. Thanks guys.
1 - 8 of 8 Posts
