Mine is the "S" so it has rear speakers. But I would imagine the cube is pre-wired for speakers as it seems to be for everything else. Most mass production car makers today only make one standard wire harness, it saves money in the loing run and makes dealer installed options a snap. Although the main wiring should be in place, you still may need a "pig-tail" harness to connect the component to the main harness. - Danmiata007 said:I too wonder if there are wires run to the rear doors for the base model.
007
Christine,ChristineK said:My Question is the head unit the same? I have read in other posts that it is not and people have gone aftermarket
I am easy and happy with my stock XM radio and Rockford setup.
