I’ve tried all the online tricks I can find and none seem to work. How can I get multiple wife’s Cube going again? Is there a fuse I can pull? If so where? I found the cabin fuse panel but I don’t know which fuse it is. Are there more fuses somewhere else?
help!!!!
1. take steering wheel underneath panel off, there is a gray control box with 2 security screws holding it on ( take the 2 screws out and go to a hardware store and find 2 screws with same thread pattern to put back in
2. tap on the box when trying to start and see if it allows you to start the car
3. if this doesn't work there is a video online that shows you where to solder one small spot inside the box to bypass the antitheft system
help!!!!
Just curious... How many wives do you have?
I would love to give these developers and programmers props for fixing all of the issues that I have been facing for the past couple of weeks with this new driver update. I can’t express my happiness enough because I can finally get to finish my project with little to no hassle because my device is not going to crash every time I use it. I usually go to their site and report these roblox pc bugs and issues to get the developers’ attention while I am playing The Christmas Carole Quest of The Sims. Good thing they responded with this update as quickly as the did.
