Beat_box said:
Square1 said:
For those of you thinking of adding the auto light function to your cube you're in luck. I had my glovebox out today looking for a better place for my GPS antenna. While I had my head under there I looked to see if there were any connector plugs there without a home. Well, like the fog light additions it too should be plug-N-play. The plug is taped up to the main harness just like the connector for the fogs. So all you'll need is the optical sensor, the correct housing, and the correct turn signal stalk with the auto switch on it. - Dan
Wow, great to know that. Now how do we get a hold of the sensor and housing ?
Part number for the light sensor is: 28576-1HH0A lists for $117.17
Part number for the bezel (housing is: 27721-5L300 lists for 22.00
Part number for the sun sensor is: 68486-1FC3A lists for $12.83
Keep in mind that you will also need the TS Stalk and I’m not sure of the part number, but I think it’s 25560-1AA0A which is for the LS and KROM without Fogs and lists for $138.22. If you have fogs and want to add auto lights I believe the part number is 25560-JV51A and lists for 102.17. These numbers will have to be confirmed with Nissan.
When I bought my fog light kit I got one for a cube with auto lights. So I’m already set. Just need to get the light sensor….in due time.
Also from what I understand the cubes equipped with auto lights are also equipped with automatic temperature control, so the bezel they sell is for mounting both the light sensor as well as the sun sensor. I think what I’m going to do when I do this add on, I’m just going to get the light sensor and modify my current blank off plate that’s covering the opening now. - Dan
