2013 Metallic Grey Cube S
Hey everyone! I recently put fog lights on my 2013 Cube S, and found a column switch from a 2009 Murano at a junkyard that fit perfectly. I now have a column switch that has an “auto”function for the headlights, and thought I’d look into adding that upgrade as well. I found a sensor at the junkyard off a few Nissans, but I cannot find the corresponding connectors under the dash of my Cube. I read a few posts in this forum about all harnesses being the same in all Cube models, But all the threads I’ve read on this topic kind of fizzled out… Does any know all the pieces we need to do this upgrade? I found a guy close by parting out a Krom model, and I’m waiting to see if he’ll let me pick what I need.
Advise? Feedback - pro or con? This isn’t a life or death improvement, but of it’s do-able without heroics, it would be kind of cool to have.
Maybe even upgrade to auto climate control!:)
It is likely that the base S model does not have the harness option since automatic headlight were not available until later years. FYI, my 2009 GTR is loaded and did not come equipped with auto headlights
I suspect you are correct. I was hopeful because of the factory pre-wiring for fog lights. I’ll wait for a Cube with auto lights to show up at a junkyard (might be a long wait!) or just let it go and enjoy what I have.
Thanks for the response.
