Does anyone else get a grind in the dash when you turn on your AC?
I get a groan from the compressor.jasonbillups said:Does anyone else get a grind in the dash when you turn on your AC?
ChristineK said:What I want to know is what is the servo sound when you turn off the engine and open the door. It is behind the instrument cluster. Once you grab the handle there is a zip sound, what is that?? ???
I have a feeling it is associated with the push button stop/start. Once you turn the engine off, the doors unlock, then you open the door and ZIIIIP. But maybe it is a steering wheel lock, makes sence and it is in the right location. I have ZERO issues with the vehicle, just curious what the noise is.CubeLuvIt said:ChristineK said:What I want to know is what is the servo sound when you turn off the engine and open the door. It is behind the instrument cluster. Once you grab the handle there is a zip sound, what is that?? ???
I have a feeling it it the steering wheel locking mechanism. ??
Maybe somebody can enlighten us. :yes:
Have not heard the zip sound.What handle are you grabbing.
Japanese call the steering wheel "Handle" pronounced with Japanese intonation.
Cheers,
Bryan.
Yup. That's about what I was thinking this morning.ChristineK said:Alternator clutch HUHSounds like the old muffler bearing trick :yes:
Mine makes noise but it is not an unusual sound, my little FIT is similar as it is a tiny motor trying to turn all that.
He may have misspoke and meant the compressor clutch. But...ya never know. :no: 8)Boxcar said:another guy that came up said it sounded like the alternator clutch. As far as I know there is no such thing.
No, there is such a thing as an alternator clutch. I know some motorcycles have them when they are driven by internal chains from the crankshaft. It helps lessen the the shock/load on the system during rapid rpm changes.ChristineK said:Alternator clutch HUHSounds like the old muffler bearing trick :yes:
i get the same sound sounds like a gyro spooling downgreed mine too. You can totally hear the compressor kick on. Sounds normal.
What I want to know is what is the servo sound when you turn off the engine and open the door. It is behind the instrument cluster. Once you grab the handle there is a zip sound, what is that?? Huh?
