We have a 2011 Cube Krom with 114K miles on it. About 2 months ago the A/C went out. The shop I took it to replaced the compressor, condenser, dryer, pressure switch and radiator fan. The entire system was flushed and placed on a vacuum and then recharged to factory specifications. When we got the car back the A/C was blowing cold. Then it started to work intermittently. It would blow cold while driving it. We turn the car off and when we got in to leave the compressor would kick on for a few seconds and then shut off. Other times it would not come on at all. The shop has checked all of the pressures and they reported they are within normal ranges. It does have Automatic Climate Control. Thinking it may be a sensor. Has anyone else experienced this issue and if yes how did you fix it?
